Wood bending members endnotched on compression face
This question pertains to the section 3.4.3.2(e) of the 2001 NDS. This formula is completely different than the one listed in the 1994 UBC. The 94 UBC lists the value of d' rather than dn. The 1994 UBC formula seems to reflect a chamfer cut beam rather than the notch shown in the 2001 NDS. Can anyone clarify that the value should be dn and not d'. And does this apply to chamfer cuts or just straight notches. Lastly, does this same set of equations apply to GLB's?
RE: Wood bending members endnotched on compression face
Mike McCann
McCann Engineering
woodengineer
