Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...I have found your site brilliant. What makes it good are the people that contribute to the site..."
Geography
Glassfiber Reinforced Epoxy Pipe - Poisson's ratio
Arline (Industrial)
16 Aug 07 15:35
I am doing deflection analysis of a pipe using GRE (Glass reinforced epoxy) pipe for which i ahve the following properties @ 21 Deg. C from material supplier
Hoop Tensile modulus = 23250 MPa
Poisson's ratio axial/hoop = 0.93
Axial Tensile Modulus = 10000 MPa
Poisson's ratio hoop/axial = 0.40
In FEA when i enter the poisson's ratios i get a message that the values ae not practical or with these values strain energy will be negative. I am using transvere isotropic format for GRE in FEA.
Will you suggest me on how to correct the problem of poissonss ratio.
40818 (Aerospace)
16 Aug 07 16:34
Not sure if i have read your post correctly, but i wouldnt use an isotropic material for your composite.
Where did you determine your youngs modulus from, it seems high?
Arline (Industrial)
16 Aug 07 16:41
I got the young's modulus from supplier. I am using transverse isotropic i.e E2=E3 (hoop plane).
ANSYS is showing an error in poisson's ratio. I was thinking that poisson's ratio of 0.93 is not correct. but i am not sure.
Please suggest.
Arline
40818 (Aerospace)
17 Aug 07 3:24
Did i say youngs modulus?? I meant to say Mr Poisson's was very high (0.93)
jedward (Aerospace)
17 Aug 07 11:33
when the poisson ratio approaches 0.5 most results are expected to explode.  incompressible materials (those maintaining volum under load) have values of about 0.49
check for more appropriate values
Arline (Industrial)
17 Aug 07 12:25
Hoop Tensile modulus = 25200 MPa
Poisson's ratio axial/hoop = 0.65
Axial Tensile Modulus = 12500 MPa
Above are the revised properties after speaking material supplier.
Can somebody help in understanding the "Poisson's Ratio AXIAL/HOOP". I typically always seen as just poisson's ratio but why they are saying that Axial/hoop and Hoop/Axial.
Assume the pipe axis in Z-direction, then what will be PR(Poisson's ratio ) in XY, YZ & ZX directions from above given values.
Which formula i need to use to calculate shear modulus for transverse isotropic materials.
Please help me in my learnings about composite.
Close Box
Join Eng-Tips® Today!
Join Us             Close
