Culmann's Method
Culmann's Method
Culmann's Method
Does anybody know where I could find a detailed procedure on how to perform Culmann's method in regards to anchored sheet pile retaining walls?  To eliminate any confusion, the procedure I am referring to analyzes the possibility of the anchor inducing a surcharge load on the retaining wall.
Another quick question on the same topic... Would the anchor slab/wall be considered "stable" if the base was below the natural slope (natural slope being a slope at an angle phi from the tip of the retaining wall)?
Thanks!
RE: Culmann's Method
craigmcg,
Culmann's method is a graphical method using trial and error to locate the critical case for slope stability problems, especially when the backslope has non-uniform geometry.
The Caltrans Trenching and Shoring manual has several worked examples employing this approach and should not be too difficult to locate for download. It also has a good section on trenching and shoring adjacent to railroads, a subject that is not widely discussed in many texts or manuals.
The avaialble passive resistance below the dredge line/toe of the wall depends on the slope angle, spacing of the embedded elements and depth of embedment.
Jeff
jdonville:  cook
Why don't you try with Talren software, with that you can analise any section that you need.
vulcanhammer,
Thanks for posting the link.
Jeff
