New Code Cases
4
New Code Cases
New Code Cases
4
If you don't want to or can't wait for IHS to publish a code case, you can get recently approved but not yet published VIII code cases here: http://cstools.asme.org/csconnect/CommitteePages.cfm?Committee=N20110000&CommitteeCodeCases=yes
For other sections, go here: http://cstools.asme.org/csconnect/CommitteePages.cfm?Committee=N20000000
and click on the appropriate section, then on the lower left hand side click on "Code Cases" under the "Publication Information" section.
When you choose a code case, click on the "View the Code Case File" link to see code case write-up.
jt
