Pumping silicon oil
Pumping silicon oil
Anyone got much experience of silicon oils as heat transfer fluids.
I am working on some systems using positive displacement pumps to move approx. 12 lpm of silicon oil (Sil 180) at 5.5bar. The fluid is anywhere between -30°C & + 150°C.
The pump manufacturer insists the oils are compatible, but they continue to leak.
I'm guessing the temperature range of the fluid may be the issue, causing excessive expansion & contraction.
Anyone know of any pumps that may do the job?
The NESLAB specialists in the UK
http://www.weekstechnic.com/products/index.php
RE: Pumping silicon oil
