H-20 Rated Access Hatch for wet well & valve vault
Due to space limitation, we were forced to put a sewer wet-well in the middle of a residential street (light residential traffic with max speed limit 30 Mph). Can anyone recommend a steel/aluminum access hatch (w/ clear opening around 30"X36") that I can use for this type of situation? Most of the access hatches that I've seen have an H-20 rating but specifically listed to be used only for "off-street" location.
RE: H-20 Rated Access Hatch for wet well & valve vault
Technocover would design a fabricate anything you like, to any size you like, to take any loading, but you pay for it.
Richard A. Cornelius, P.E.
WWW.amlinereast.com
