High temp helium service
Hi all.
What cast material would be used for a valve body in Helium service, temperature up to 350°C, pressure max 90 bar?
We were informed, that under these condition Helium tends to creep through any kind of casted material so only forged material to be used.
RE: High temp helium service
Cast grey iron is one of the easiest materials to cast without voids.  But, it's still a sieve compared to forged steel or forged brass.  Why would you not want to use a forged valve body?
I agree with btreublood.
I´ve seen specs with that conditions using
forged CS gatevalves acc B16.34
Forgings lack the pathways that exist in castings.
