Maximum Flowrate Through Heat Exchanger
We have a heat exchanger, typ AES, that is designed to cool about 1000,000 lb/hr of light hydrocarbon liquid in the shell side with pressure drop of 3 psi. The cooling media is sea water, which is placed in the tube side.
My question:
How can I estimate the maximum hydrocarbon flow rate that I can cool through the heat exchanger? what the relationship bewteen flow rate and pressure drop in a heat exchanger?
Many thanks
My question:
Many thanks
RE: Maximum Flowrate Through Heat Exchanger
Thus, if you doubled your flow rate, your pressure drop would be about four times greater.
-Christine
-Christine
