Thread forming screws
I'm not very familiar with thread forming screws (not to be confused with thread cutting screws)
How do you find the appropriate drill size for these? I want to attach two thick aluminum plates together, quickly, without having to tap holes. They seem like the best method, but these "odd" threads like 10-16 and 8-18 leave me hanging.
Tap/drill charts list drill size for some % thread engagement... for machine screws.
Any ideas or drill charts out there?
RE: Thread forming screws
http:/
Cory
Please see FAQ731-376: Eng-Tips.com Forum Policies for tips on how to make the best use of Eng-Tips Fora.
I guess I must have been looking at sheet metal screws or something.
J
For example, if I need to drill and tap 3/8 UNC into an appropriate metal piece, knowing that the pitch for the National Coarse thread of size 0.375 inches is 16 TPI, I would get:
0.375 - 1/16 = 0.375 - 0.062 = 0.313 inches
This corresponds to 5/16 inch drill size.
You would need to use a drill size chart to find the closest corresponding fractional size. This example was presented because of simplicity.
Kenneth J Hueston, PEng
Principal
Sturni-Hueston Engineering Inc
Edmonton, Alberta Canada
You missed the first line of the first post.
"...thread forming ...(not to be confused with thread cutting...)"
Your 3/8-16 needs a .3445 dia. for 75% thread.
This corresponds to a 8.75mm drill size.
5/16 drill size is the recommended hole for tapping 3/8-16 UNC-2B listed in the Machinist Handbook. The method I've mentioned is the classical way of deriving drill size.
Typically listing a metric drill size for an imperial thread is not a recommended machine shop practice. Although I have used it on very rare ocassions, it has always generated confusion with machinists. Specifying 8.75 mm drill size for a 3/8-16 UNC-2B box would be unusual, I would wonder if there would be a significance difference in thread performance compared to 5/16.
But then again, that is just me.
Principal
Good Luck
johnwm
________________________________________________________
To get the best from these forums read FAQ731-376: Eng-Tips.com Forum Policies before posting
Steam Engine enthusiasts
Steam Engine Prints
