SSR For DC control
SSR For DC control
Hello
I want to control a DC motor with an SSR. I had a Crydon D1D20 and it failed close. Need to work at about 20 Hz (On/off about 40 times per second).
Output - 30 VDC @ 5 Amp Max (1 hp dc motor)
Input - 5 - 10 VDC input.
Was thinking about a power-IO relay
RE: SSR For DC control
Make sure you heatsink it well. Make sure you include a diode across it's output. Make sure you get an over rated SSR, 3 or 4x the current.
Keith Cress
I'd google and look around a bit for things like:
http://
or
http://www.geckodrive.com/product.cfm?pid=13
"DC speed control"
"DC motor control"
Etc.
Keith Cress
Adding to Keith's links: www.4qd.co.uk
Sometimes I only open my mouth to swap feet...
