Block insertion
Block insertion
Block insertion
I'm currently running SW 2007 sp2.2 and am having some issues when I insert a block into a drawing.
When I insert "Block A", it turns into a different block. When I look at the tree, it shows the "Block A" that I am trying to insert and also "Block 1". The "Block 1" is the actual block that I am trying to insert, but it should be "Block A".
I don't know if that makes sense to anyone, I can attempt to elaborate if need be...is anyone else having this issue?
Boottmills
RE: Block insertion
boottmills,
It sounds as though you have a different block named the same as the one you are trying to insert. Try deleting all the blocks listed in the tree and try re-inserting to see if it comes in correctly. If that works you may want to rename the offending block to something else.
Best Regards,
Jon Knabenschuh
Gemini CAD Solutions
http://www.geminicadworks.com
Challenges are what makes life interesting; overcoming them is what makes life meaningful.
Solidworks 2007
RE: Block insertion
There are no blocks listed in the tree. I have attempted to insert a block in a blank drawing template and the same thing happens.
Boottmills
RE: Block insertion
boottmills,
Just so I understand that you are looking in the correct place  there are no blocks listed under the "Blocks" folder when it is expanded? If there are any blocks listed as the same name of the one you are inserting it is only going to use the one that is embedded in the template and not the one that you are trying to insert.
See Example here: http://img236.imageshack.us/img236/8427/drawingblocksjk1.png
Best Regards,
Jon Knabenschuh
Solidworks 2007
RE: Block insertion
That is correct. The template has no blocks associated with it. What is happpening seems almost as if when I insert a block it is creating an additional block and causing me to insert that one instead.
Boottmills
RE: Block insertion
Do you have 2 blocks with the same name in 2 different folders. if so, make sure your file path is correct.
RE: Block insertion
I am not sure what else would cause this problem other than what sirbartoo had suggested. Try a restart of the system and try the things we have suggested again.
It may also be a bug that you are seeing and probably upgrading to the latest SP will fix the problem.
Best Regards,
Jon Knabenschuh
Solidworks 2007
