Scriping problem:how to get nodal coordinate of an instance?
Hi
I m trying to read the COORD data from an specifies instance nodes.But i get an following error:
this is what i wrote:
myOdb = visualization.openOdb(path='initial.odb',readOnly=FALSE)
firstStep = myOdb.steps['forming']
coords0=frame0.fieldOutputs['COORD']
coordxValue=coords0.values
coordxinstance=coordxValue.instance(name='TUBE-1',object=)
the error is :
AttributeError:'FieldValueArray' object has no Attribute 'instance'
And also i m not sure if i can get each Coordinate(x,y,z) using : iValue.data[i]
Thank you
Dariush
the error is :
Thank you
Dariush
