Component only in assembly
I'm using Pro/E 2001
Is it possible to create a component that is stored in the assembly file and doesn't create a separate part file?
For example, I want to add weld metal to an assembly, can I add it to the assembly or do I have to create a new part for the weld metal and assemble it?
I don't want to use the merge function, the drawing needs to show that two separate items exist and have been welded.
RE: Component only in assembly
