ASME VIII Div 1 Code Case 2660-1
Does anyone have experience with or has used ASME VIII Div 1 Code Case 2660-1..?
When would you use this code case instead of the requirements of UG-32(d)/(e) and 1-4(c)/(d)?
RE: ASME VIII Div 1 Code Case 2660-1
I believe code cases has only reached 2576, at least that is what I can download from IHS.  They have the latest issued documents.  So what is 2660?
Considering the reference is to Ellipsoidal heads the Code Case is probably 2260.
