BPFI Frequency
BPFI Frequency
BPFI Frequency
Hello everyone.
Does BPFI frequencies first occur at a frequency less than 1x running speed.
RE: BPFI Frequency
If you mean what I think you mean then no, unless you have fewer than 1 but more than zero, blades.
if that makes no sense, well you need to explain what you are talking about.
Cheers
Greg Locock
Please see FAQ731-376: Eng-Tips.com Forum Policies for tips on how to make the best use of Eng-Tips.
RE: BPFI Frequency
Ball Pass Frequency of the inner race for conrad beairng is approximately 0.6 * number of rolling elements times the running speed.
So for a 8-ball bearing it would be somewhere just less than 5 times turning speed.  (I'm assuming outer race is stationary and inner race rotating).  There are formulas to calculate it exactly if you know ball diameter, race diameters, and contact angles. Or you can typically look it up in most vib programs if you know bearing part number and manfuacturer
RE: BPFI Frequency
Ah, not to be confused with blade pass frequency in a fan, obviously!
Cheers
Greg Locock
RE: BPFI Frequency
Nor to be confused with the Beer Pouring Frequency...
