Cleared Chart Legend - How to Get it Back?
Once I've cleared an Excel data series chart legend entry, how do I turn it back on?
RE: Cleared Chart Legend - How to Get it Back?
1) On chart page, Chart/Chart Options/Legend, check "Show Legend" and check one of the locations, (Bottom, etc.)
If you are talking about getting just the text for one entry in the legend, try this:
2) On chart page, Chart/Source Data/Series. At the bottom left will be a list of all the data series you have plotted on your chart. Select the data series which you want to name. In "Name:" at the right, you'll see what will appear in the Legend when the Legend is turned on. You can type some text in the Name: box, or you can click on the small button to the right of this Name: box (called the Collapse Dialogue button), then point to a navigate to a worksheet, and select the cell which has the text you want in the legend for this data series.
Sometime in the past, someone might have clicked in the legend itself and cleared it. How would I undo that?
I don't know if you do backups--sometimes it's worth it to return to the backup directory and restore what was there.
I don't know if this is your problem, but I've had this happen before. The Name: box points to a cell in a worksheet. I delete the row or column with that particular cell. Now the Name: box shows #REF! because I've deleted the reference. There is another instance that showed <blank> in the Name: box, but now I can't recreate that instance, so I can't tell you why <blank> showed up.
To clear I select the legend, select the series name, then right click and select clear. Poof, it's gone. I just don't know how to undo it without recreating the whole series.
that's me, knocking my head with a stick. So here's what I did. I selected the legend in my chart, then clicked the entire label for my Series 1. Delete button makes it go away with no apparent way to retrieve it. What if I select the ENTIRE LEGEND, then delete? Legend gone. Now I went to Chart/Chart Options/Legend, checked "Show Legend" and checked one of the locations, (Bottom, etc.). The Legend reappears with the Series 1 label and symbol that I deleted in the previous step. Does that work for you?
Cheers,
Joerd
Please see FAQ731-376: Eng-Tips.com Forum Policies for tips on how to make the best use of Eng-Tips.
