555 timer or VCO
555 timer or VCO
555 timer or VCO
I need to create a 40 Hz square wave, "ON" = +5V, time high = 2.3 miliseconds for an automotive application.
I'm looking for recomendations & advice on a 555 timer using an isolation diode or a voltage controlled regulator for this application.
I'm familiar with the 555, but have no experience with the VCO.
RE: 555 timer or VCO
Use a dual timer, one as 40 Hz osc, the other as 2.3 ms
one-shot. (By the way, the square wave is 12.5 ms high,
same low. )
What are the isolation diode and the VCO for ?
<nbucska@pcperipherals.com>
556 is dual 555 timer ic and agree with previous post.
vco uses varactor diodes to trim frequency determining capacitance
What are your rise / fall time requirements?
I need to build a 555 timer that works in the 7.8 HZ; in witch the oscillator itself does not over heat.
try to stay away from the 555 in automotive applications!  these devices do very poorly over temperature.  Also, they are extremely sloppy.
melone,
Your statement is not what I have found. Could you elaborate on its shortcomings?
There are many possible solutions to this! As always performance and price matters greatly. Some thoughts:
  Being a microcontroller fanatic I would have used a cheap micro if I needed accuracy and well defined rise times, and get some "intelligence" for free, like startup properties etc.
  A nice low cost solution could be an op-amp in oscillator configuration, with 2 diodes giving control of hi/lo durations.
  Even simpler would be using a cmos 40106 hex schmitt trigger inverter, 1C, 2R and 2 diodes. Slightly better would be adding an MMV stage (just use inverter no 2 of the 6 available). This would not produce the best performance in the world, but probably compete for the cheapest solution (there are 4-5 inverters "free" for other purposes). Bear in mind that the resulting timing will vary from different manufacturers and/or production batches.
  Schematics should be readily available, if needed just let me know.
