HELP!--Inactive Degrees of Freedom in Abacus/CAE
I am attempting to model a plate that is twisting about the x axis.  I want to restrain half of the plate about the y mid axis and then add a moment to the free end to simulate twisting.
When I restrain half the plate and run it everything works fine but then when I add the moment to the end of the plate I get an error reading
"Error in job Job-1: 1 nodes have inactive dof on which boundary conditions are specified. The nodes have been identified in node set ErrNodeBCInactiveDof."
I am not sure how to solve this,
Any ideas?
Thanks much
RE: HELP!--Inactive Degrees of Freedom in Abacus/CAE
Look in Viewer to see the set of nodes where the error occurs. You've probably applied a load to nodes that have been restrained or tied.
corus
