Problem restarting a fluidic analysis
Hi
I am having a small problem restarting a fluidic analysis.
Basically I want to restart a transient fluid analysis. However when I do the restart I was to create a new *.db and continuing the analysis in this new database from the previous time step but write the remaining result to the new corresponding *.rfl file.
For example I have successfully run a Fluid1.db analysis file to 6 us.  I now wish to call this file a new name for example Fluid2.db and continue the analysis in this new database from this 6us time step up to 20us. However I wish to write the remaining 14us to the new corresponding Fluid2.rfl file. This is the problem I am having.  How do I do this??
Please see the restart file I have below which works fine if I am staying the same Fluid 1 database.
Can anyone suggest how to improve this file.??
This is the Restart file
/batch
/CONFIG,NRES,9000
resume,Fluid1,db
/filname,Fluid2
/prep7
dt   = 0.05
ftime=20.00
FLDATA4,TIME,STEP,dt,
FLDATA4,TIME,ISTEP,dt,    ! sets the first time step
FLDATA4,TIME,NUMB,10000,  ! sets the maximum number of steps
FLDATA4,TIME,GLOB,1000,   ! sets the maximum number of iterations
                          ! per time step
FLDATA32,REST,TIME,-6.00
nt=ftime/dt
ns=6.00/dt+1
! Put this in to pick up the last displacement value from the disp.inp file
*dim,dnewB,array,1,1,1
*vread,dnewB(1),disp,inp
(f22.16)
disp=dnewB(1,1,1)
uyy=disp
vyy=0.00
allsel,all
fini
*do,i,ns,nt,1
   ctime=(i-1)*dt
   /prep7
   FLDATA4,TIME,TEND,ctime
   cmsel,s,paddle,node
   d,all,ux,0
   d,all,uy,uyy
   d,all,vx,0
   d,all,vy,vyy
   d,all,enke,-1
   allsel,all
   fini
   /SOLU
   allsel,all
   SOLVE
   fini
*enddo
save
