Vaiable thermal conductivity
Thermal conductivity varies with temperature. In steady state HT, a single TC value can be entered for a given temperature. I seem to remember an input method in ALGOR to enter thermal conductivity values over a temperature range. I haven't done HT analysis for awhile and now I can't figure out how to do this, or if it's even possible.
Can someone point me in the correct direction?
RE: Vaiable thermal conductivity
Garland E. Borowski, PE
Borowski Engineering & Analytical Services, Inc.
Lower Alabama SolidWorks Users Group
Magnitude The Finite Element Analysis Magazine for the Engineering Community
Transient HT is used for, perhaps, equipment start-up where heat inputs vary with time. Nothing is necessarily "non-linear", but you have a time-dependent component to the analysis. The event you are analyzing occurs over a period of time and as things "heat up", you want to change the thermal conductivity. This is generally done with a piecewise linear curve much like you input a varying modulus for structures.
Unless I'm missing something, the difference is much like performing a linear analysis vs. a dynamic analysis. Both are still linear, but only the dynamic analysis has a time-dependent component.
