UNI equivalent
UNI equivalent
anybody know the SAE or DIN equivalent to the following designation is?
UNI 6682 - 70 (Fe R37)?
Alternatively, an online resource where one might get this information would be helpful also.
RE: UNI equivalent
http://www.matweb.com/index.asp?ckck=1
KENAT, probably the least qualified checker you'll ever meet...
RE: UNI equivalent
UNI 6682:1987 Prodotti finiti piatti di acciai laminati a caldo e a freddo. Lamiere e nastri destinati alla fabbricazione di tubi saldati. ["Hot and cold rolled flat finished steel products. Plates, sheets and coils intended for production of welded tubes."]
Available in Italian only, for 34 Euros: http://w
Perhaps buy, then use MatWeb's composition search.
I searched briefly online & also the 1979 edition of ASM's Worldwide Guide to Equivalent irons and Steels. No luck.
Try the links at the FAQ
FAQ330-286: Looking for material identifications, specs and equivalents on the net?
Register at Key-to-Steel & try their free PowerDemo.
http://www.key-to-steel.com/
