Direct Mixing for heating problem..
Dear all helpful member,
I was trying to upgrading my oil treating facility heating system. We want to heat a crude oil steam using waste steam condensate. Heating is done by injecting the steam condensate into the crude oil stream. Downstream, the mix temperature of oil and condensate will be measured by temperature element and signal from this element is used as feed for flow control valve (FCV) which controlling the rate of condensate injected to oil stream.
My question: is there any method to determine the pipe distance requirement between point of mixing and point of measurement? I want the transmitter to measure quite real mix temperature, and for this i think both of fluid should already well mix before it is measured.
thanks all
cheers,
-Rayz-
RE: Direct Mixing for heating problem..
How do you prevent segregation ?
25362, what do you mean by segregation? you mean that the condensate will not mix with the fluid?
The crude oil i'm talking here is mostly consist of water (about 80 to 90%)flowing in turbulent manner. So i think steam condensate generally can be mixed with the fluid.
We trying to heat this fluid from 170 F to 190 F
thanks alot,
Rayz
With turbulent flow and a thin fluid to start, you should get a good reading after 10 pipe diameters.
25362 is right-without the turbulent flow the oil will separate from the water, and even WITH turbulent flow the best you can hope for is an emulsion, not a solution.  Won't make much difference for heat transfer.
