3D sketch question: simplifying the process
Hi, my name is spencer.  Im fairly green when it comes to solidworks and im having trouble finding an easy way to build a chair for the company that i work for. The chair's seat is going to be constructed of an 1/8" steel wire mesh, and has a fair number of compound curves.  What im wondering is if there is an easier way to construct a series (or array rather?) of sweeps.  Right now ive started by lofting a surface for the seat, and then used the face curves tool to extract an array of 3d sketches to use as paths in sweeps. But then i have to create a plane normal to each sketch, and sketch profiles for each individual sweep and its very time consuming. Is there a way i can simplify that process, and also simplify the design tree, having 50 some odd sketches doesn't seem right.  Any help you can give me would be much appreciated, thanks.
-Spence
RE: 3D sketch question: simplifying the process
That sounds like the way to do it if you need that much model complexity.  Is this like a Bertoia chair or something?  If not, can you stick with the non-wired model and use a surface with an applied texture?  (Just wondering how much detail you truly need in the model.)
Jeff Mowry
www.industrialdesignhaus.com
Reason trumps all.  And awe transcends reason.
Yeah, Bertoia is exactly the idea. Well, im glad to know ive got the right idea, thanks a bunch for the advice.
-spence
