Power Factor in 3 phase system
I monitored my high pressure air compressor over the weekend and noticed that I had very different PF's on the 2 phases that the monitor logs, I would like to have any and all help to explain it.  Phase A had a PF of .254 Phase B had a pf of .929 and system pf was .661.  These readings are an average of 10,000 readings.
RE: Power Factor in 3 phase system
My guess is that whatever you are using to get this data is connected incorrectly.
Check phase and POLARITY of all CT and PT connections.
Could it be a two watt meter type of connection where you need the results of both meters for three phase values and the results of neither meter by itself means anything?
