No text appearing in Inventor drawings
Hi, I'm having a problem with Inventor. I don't think I did anything to cause this, but I have no idea to fix it. When I am making a drawing in Inventor 10, dimensions show up just fine, as do things like thread notations and so on, but I cannot insert text either on its own or on a leader. I also can't add extra text after dimensions.
If I am trying to do leader text, the arrow will appear but not the text.
Thanks in advance..
Thanks in advance..
RE: No text appearing in Inventor drawings
I am sorry if you have no idea why you are getting this response but this question has been answered several HUNDRED times on multiple forums. Run a search in the forum for missing text, and next time read the other posts before you ask what has now become a STUPID question.
David
Thanks for the 'help', I will be sure to remember this should I ever see you asking a question somewhere.
Aardvarkdw, that was pretty harsh. How would you like someone out of the blue treating you like a dumb a$$ just because you asked a question you didn't know the answer to?
This problem has been around for long enough and been rehashed so many times that when it comes up it practically screams "I don't have time to look for an answer so I am going to waste your time instead.)
I apologize for my abrupt response.
David
My suggestion is to stop answering questions if they annoy you. You must be a joy to work with.
ht
David
http://d
I know you're on the right track. Just have to figure out how to get rid of that update.
