Sheet Metal views
Sheet Metal views
Sheet Metal views
Is it possible to show a sheet-metal part in both its "Sheet-Metal" AND its "Flatten-Bends" states at the same time?
(not sure of the correct terminologies here...)
Multiple windows or split windows or ??
Active/inactive windows?
RE: Sheet Metal views
In a drawing ... Yes
In a model ... No
cheers
OK, thanks
You could create an assembly with both the folded and unfolded instance if you wanted to see a 3d comparison.
-b
