Water required for quenching
I have total flow rate 1448 SCFM at 1911 F and i want reduce the temperature till 1200 F. i am trying to caculate amount of water required to quench. water will be available at 70 F.
Please help me out  how i shloud use sensible heat and latent heat of water for this calculation.
Vishal
RE: Water required for quenching
Donald R. Woods in his Process Design and Engineering Practice, PTR Prentice Hall, has a section on hot gas quenching with worked out examples, that may be applicable.
