Weight/ Surface area of steel pipe support
Could anyone please advise which website provides engineering formula to calulate weight & surface area of steel pipe supports? Thanks in advance
RE: Weight/ Surface area of steel pipe support
I do not think I understand your question.
The weights of pipe supports are provided by the manufacturer's catalog.
The weights and areas of steel pipe are provided by many reference books (e.g., the NAVCO Datalog).
I suspect that is not what you are asking for so could you please rephrase your question?
Regards, John.
I have some tables from piping- and chemical companies.
Is there no engineer in your neighbourhood with a table of this?
Greetings
there are only tables.
Don't know how You can get these,
maybe You can look on the internetsite of lisega or hesterberg for weights.
Most big companies have them too(dow,shell etc)
maybe by googling?
succes.
