Help please, I am looking for a Stainless to replace EN32b
Firstly appologies if this is in the wrong area....
Ok now my questions, I have been making steel suspension parts for racing for some years, however I have just been asked to make a set out of stainless steel for a road car ? I have always "shied" away from STST because of stress, fracture, fatigue etc.... are there improved STST that can be used ? The part is under compressive, tensile and bending stresses, it sits under a car so water, salt etc get to give it a good going over. One end is threaded and the threaded section has been known to fail (not on any of mine I hasten to add) I use a 7/16unJf thread form and bead blast then ZINC PASSIVATE. Ok so the STST won't be bead blast or should it ??? IWe can't afford to lose business, however better that than lives... Many thanks for any advice. Martin
RE: Help please, I am looking for a Stainless to replace EN32b
Still trying to help you stop corrosion.
formerly Trent Tube, now Plymouth Tube
eblessman@plymouth.com
or edstainless@earthlink.net
Thanks for the reply, it is machined from 5/8"bar, with a 1/2" dia stepdown, then stepping down to 7/16unJf using EN32B (approx 460N/mm^2) steel I calculate that the core is 0.3762" 9.556mm
:- CSA = (pi*D^2)/4 = 71.71mm^2 :- culminating in about 3360Kg Of tensile load... I understand that there is STST's with high tensile properties, however I am more worried about the fracture, fatigue issues that I have heard about STST, i.e. origination from high localised areas of Chromium etc...
Also I have looked at Duplex and super duplex, they appear to have excellent qualities, however, what are the fracture and fatigue qualities, I couldn't find any results for the duplex range of STST's.....
1 ksi = 1000 poundsf/inch2 = 6.89475 MPa
Zinc passsivated SS? Zinc is undesirable on SS; it de-passivates a normally passive SS surface. Zinc can also embrittle SS at high temperatures. The typical nitric acid passivations for SS remove zinc contamination along with free iron.
I would stay away from the super duplex because of limited availability.
You do roll the threads right? Trust me, you will want to.
Look into 2205. I am sure that there is fatigue data available. It is a very common grade.
However I do bead blast to help with fatigue etc... I have seen similar products to mine that are not bead blast and the threads have been undercut normal UNF form
I use a capstan for manufacturing these could I use a thread rolling machine on this machine... haven't rollers got to worked at a higher speed... than normal thread cutting ?
Where are you located? I know someone here that would be willing to look at it for you.
http://www.questek.com/PDF/ferriums53.pdf
http://ir.
