Difference between fmagsum and emft
What is the difference in the physical meaning in calculations of force on a body in an electrostatic field using Maxwell stress tensor through the command fmagsum and using the command emft. ANSYS 9 documentation recommends using emft to calculate force on the body in an electrostatic field. However, when I make calculation using fmagsum as well as using emft, the two methods give different answers.
Thank you in advance,
John
John
RE: Difference between fmagsum and emft
May be I didn't formulate my question correctly but my question is:
1) What is the difference between fmagsum and emft?
2) In the context of electrostatic analysis, how do I use both commands?
John
John
