HP Steam, Air and Psych Tables
I will be taking the coveted PE exam this October and have two HP calculators. The 49G has the FE software loaded and I had some difficulties with the people that programmed the calc. My 48G, I would like to set up as my backup with the tables listed above. If there are formulas which I can program, please let me know where I can find them as I can program my calc myself. Thanks for any help.
RE: HP Steam, Air and Psych Tables
A word of warning CHECK WITH YOUR LOCAL BOARD TO FIND OUT THERE CALCULATOR POLICY, SOME BOARDS WILL NOT LET YOU USED CANNED PROGRAMS that is all memory must be totally erased, a proctor may also witness or verify this.
http://www.hpcalc.org/
There are typically not programs you can enter into your calculator by hand, but programs that you can use your connection cable to download into your calculator.
This site also gets you into a number of sites that are devoted to HP calculators.
