3/8" compression fitting
I have a project that requires me to attach a 3/8" compression fitting (standard toilet connection) to the piece of equipment we are designing. I am trying to find the thread profile that is used for a compression fitting but am not having any luck. Could someone please tell me what thread standard I will need to use to get the correct profile.
RE: 3/8" compression fitting
The threads should be in accordance with ANSI B1.20.1 requirements.
Look around at:
h
and go to the column on the left and have a look at Section "F".
Regards, John.
