100% hr after sterilizing air
What is the best way to makeup air to 100% hr , after filtrating the air to be sterile.
I will make the air sterile by filtration , then I need to make it to be 100%HR , of course the water will be distillate,
Flow is about 2 m3 / min , 35.31467 f/min .
Pressure will be about 5" water column.
Thank in advance.
Thank in advance.
RE: 100% hr after sterilizing air
Knowing that sterilizing shall be kept, what kind of mean can be used? , and as the qty are so small I think to drop water at such mean.
Regards.
