"?" Mark Displayed Next To Feature Name In Feature Tree
What does this mean and how do I get rid of them?
RE: "?" Mark Displayed Next To Feature Name In Feature Tree
Are the question marks out to the right?  That usually means that you have in-context references in the part, but the document that the references are defined in is not open.  For example, if you have a hole pattern in a plate that is defined in the context of an assembly but the assembly is not open, you will get question marks on that feature.
Go to Help > SolidWorks Help Topics > Contents > FeatureManager Design Tree Conventions to see all the convention icons.
cheers
You, more than likely, have in-context relationships. Before you start removing them, you need to find out what/where. If you don't, you could end up in a heap of trouble.
As everyone above me mentioned, look in your help files. If, after that, you still have problems. Come back and let us know.
Jeff Mirisola, CSWP
SW '07 SP2.0, Dell M90, Intel 2 Duo Core, 2GB RAM, nVidia 2500M
http://designsmarter.typepad.com/jeffs_blog
