Brick Veneer Weight
Brick Veneer Weight
I submitted the calculation for the stud wall with brick veneer attached. The city of Palos Verdes engineer requested to consider and specify the weight of brick veneer. Is there anyone knowing the weight of brick veneer?
RE: Brick Veneer Weight
or
16 kN/m^3
And you may ask...Why is he in this business? I would answer "I don't know."
Mike McCann
McCann Engineering
Never, but never question engineer's judgement
If there is a particular brick manufacturer that you are using, they should be able to tell you the unit weight of their product.
If you really want to know the exact weights, email Interstate Brick in Utah (www.interstatebrick.com) and they can give you that info, in addition to structural clay masonry weights. Or if you want to call...801-280-5200.
