Rated MDMT
Rated MDMT
Under what circumstances SA105 Flanges (B16.5) will have a rated MDMT of -155DegF? What went wrong?
RE: Rated MDMT
Tom Barsh
Codeware Technical Support
RE: Rated MDMT
RE: Rated MDMT
For my nozzle assembly(Flange:SA-105,Neck:SA-106-B,Pad:SA-516-70).
Design MDMT is 30F. In the process of reducing MDMT,I calculate Level 1 MAT(Minimum allowable temp) to be 10.38 F for this nozzle assembly considering UCS-66 Impact test excemption curve.And when further reducing this MAT for Neck using curve UCS-66.1, I found out my Coincident ratios(Rts) are too small.Please see following table:
Pressure P psig S*E* (Rts=S*E*/SE) Tr?F MATR
MAWP 175 17100 1.00 0 0
Design 155 569 0.03 52839 -52839
40% MAWP 62 227 0.01 423675 -423675
Start Up 111 407 0.02 113850 -113850
Operating 123 451 0.03 90037 -90037
Now I am confused while making the decision regarding my finallly reduced MDMT.I Checked API579 chapter 3(2007 edition),On page 3-9 under STEP 4 i)1)it states that if the Rts value is less than or equal to the thresold value on UCS 66.1(which in my case is 0.3) set the MAT to -150F.
So Should I Consider the same MAT(-150F) for Nozzle flange and Pad material and set the MAT(Ultimately Final MDMT) for Nozzle assembly to be -150F or Sould I consider UCS-66(b)(1)(b) and restrict the MAT(Final redused MDMT) of the flange to -55F and hence the MAT(Final reduced MDMT) of the whole nozzle assembly to -55F?!
I really really need some ones help to clarify this confusion.
Best regards
RE: Rated MDMT
Sorry that does not answer your question and so was TomBarsh did not answer my question!
RE: Rated MDMT
RE: Rated MDMT
For low pressure applications (say less than 100PSI) UCS66 curves scared a lot of people using carbon steel pressure tank fabrications and with the calculation of Rts, UCS-66(b)(1)(b) almost telling you can use any low grade carbon steels.
RE: Rated MDMT
I am sorry that you feel that I did not answer your question.
However, you asked "Under what circumstances SA105 Flanges (B16.5) will have a rated MDMT of -155DegF?"
I directed you to ASME Code Section VIII Division 1, paragraph UCS-66(b)(3). This paragraph applies to standard B16.5 flanges as well as to other components.
Tom Barsh
RE: Rated MDMT
RE: Rated MDMT
Does UCS-66(b)(3) means: When the intended MDMT(not design MDMT)is between -55F to -155F and coincident ratio is less than or equal to the 0.35(lower thresold limit on UCS 66.1)than the componet under evaluation can assume the value of MAT(or rated MDMT) to be -155F.
Do you think my interpretation is correct?!
Thanks.
RE: Rated MDMT
Is not it correct that the SA-105 material's MDMT is restricted to -55F(accordig to UCS-66(b)(1)(b)) without performing the impect testing.
Is n't it correct when the Intended MDMT(worst condition during operation) is lower than design MDMT especially below -55F than impect testing of materail(including SA-105) is required. Or use different material such as SA-350-LF3 for flange?
RE: Rated MDMT
I don't think the question you are asking is specifically Compress related. Tom has tried to help, but if you need more, I'd suggest posting your generic ASME Code issues in the ASME Code forum. forum292: ASME (mechanical) Code Issues
jt
RE: Rated MDMT
