H4 wellhead profile
H4 wellhead profile
H4 wellhead profile
What is the angle that the ring gasket seals on?  I would prefer not to have to purchase an 18-3/4" AX or VX gasket just to get this answer.  I assume this can be publicly answered. If not, I apologize. Thanks in advance.
RE: H4 wellhead profile
Have you asked Vetco nicely?
I got irritated at paying $150 for a full face gasket, roughly 10" dia, punched out of sheet material for a different component...
Bought one, stuck it on the copier, put the copy in the equipment file with dimensions added. Won't be contributing to that profit center again.
jt
Unfortunately the photocopier is probably a terrible idea in this instance - unless you want to go to jail for a long time.   I would imagine, as drillernic says, that vetco would be the best source for this info.
This is not a flat gasket. This is a 4" tall steel gasket that seals on 2 tapers.
