Solid Edge 2D - creating a Polyline / Boundary
Hello - can anyone offer advice, I'm trying to polyline a 2D sketch. In AutoCAD I would use modify object/polyline or failing that the draw Boundary command.
I can't seem to find a silmilar command in SE, connect points doesn't seem to do the job?
Any help appreciated.
RE: Solid Edge 2D - creating a Polyline / Boundary
What specifically are you trying to do? There is no polyline command in SE. Make sure you have Tools-Maintain Relationships turned on before you try to connect points. Depending on what you are doing I would think a combination of connected endpoints and grouping would suffice.
I tried again but could only connect seperate lines rather than make a series of connected lines into one line.
