Barcode Scanning Into Access 2003
Good Afternoon everyone.
Due to development being frozen on our main system. I've been tasked on implementing another tool that will Scan Barcodes and send this data into an access Database.
Users at multiple stations will be scanning error codes ( Barcode Format) and it should populate a single access database.
Has anyone had experience with any good tools in this regard?
Thanks.
Thanks.
RE: Barcode Scanning Into Access 2003
ck1999
Our Manufacturing users will then scan these Bar Codes whenever an error occurs.
We want to collect this information into a database to find out where our main deficiencies are...
HME
Then using a Data Access Page that will be placed on every users Desktop.
They will open it up and scan in the bar code whenever there is an error.
An alternative is touch screen panels, I ahve used these alot. A bit more expensive but can provide better info. The screens can be configured to display the likely cause based on where the problem occured in the machine.
Hope this is of some help
http://www.waspbarcode.com/
Nathan Boeger
http://www.inductiveautomation.com
Total SCADA Freedom
