How do you remove all line colors from wireframe display
I have an assembly drawing. When I choose wireframe display I would like to have it display the wireframe lines without colors. Right now I get the part color as the line color. How do I get all the lines to be black?
RE: How do you remove all line colors from wireframe display
Assembly drawing or assembly model?
cheers
Tools->Options->deselect 'Use specified color..." at the bottom.
Jeff Mirisola, CSWP
SW '07 SP2.0, Dell M90, Intel 2 Duo Core, 2GB RAM, nVidia 2500M
http://designsmarter.typepad.com/jeffs_blog
"Tools->Options->deselect 'Use specified color..." at the bottom."
Tried this. Doesn't work.
"Assembly drawing or assembly model?"
Assembly model. Sorry for the mistake.
Open the offending part.
Switch to Hidden Lines Removed mode.
Go to Tools > Options > Document Properties > Colors and edit the Wireframe/HLR setting to whatever colour you want.
cheers
