Multi-Assembly BOM
Multi-Assembly BOM
Multi-Assembly BOM
Does anyone know if a traditional DOD-style, multi-assembly BOM can be created in Pro?  What I am trying to do specifically is create a two-dimensional repeat region for multiple assemblies.  The rows in this table should list all parts found in all assemblies, and the columns should list the various assemblies described by the drawing.  The grid defined by these rows and columns should be poulated with the quantity of each component used by each particular assembly.  These assemblies are not family-table instances.
RE: Multi-Assembly BOM
Re-reading the thread it might not help but I seem to remember that playing with the properties does get you to sub-assemblies eventually.
I think there is an option of &rpt.level that will show the level of the item in the bom.
