Cordless Drill Torque at Speed
Is there a way to find out the approximate torque of a cordless drill at a certain speed? All of the manufacturers I have found only list max torque and then speed ranges. Is the max torque when the unit is stalled?
Mike
Mike
RE: Cordless Drill Torque at Speed
http://www.uryu.co.jp/english/pdf/07_OTHERS.pdf
You might also look on the web for companies that rent testing equipment, such as:
http://www.atecorp.com/
I am trying to get an idea of how much power this drill can actually put out. Might it put out 1 hp? Say 35 in.lbs. of torque at 1800 RPM or 300 in.lbs at 210 RPM?
I have never worked with such a beefy drill but would love to hear from someone who has and the manufacturer (and other drill makers) has not been very helpful.
Mike
Demagnetized motor magnets
Blown Power Transistors
A Battery taken to it's knees
Brushless motor controllers sense the motor current and limit the current to a maximum value.
