chlorine contact design for 2 BR residence
Can someone recommend a design guide or example for chlorine contact tank for residential application?
thanks.
RE: chlorine contact design for 2 BR residence
Denpending upon your reason for chlorinating your water the recommended contact time is 20 - 30 minutes.  Whatever the flow rate is in gpm the tank size should be the flow rate times 20 or 30.  BR number does not tell us flow rate.  In addition, we would need to know the cause that calls for chlorination.
Gary Schreiber, CWS VI
The Purolite Co.
