Stresses on Buried Pipe
I don't know if this is the appropriate forum to ask this question, but I will give it a try.
Can anyone point me to references that would help me evaluate the strength of a pvc pipe to be installed under a large coal pile?
RE: Stresses on Buried Pipe
If it PE you may well direction drill the pipeline.
Geoffrey D Stone FIMechE C.Eng;FIEAust CP Eng
www.waterhammer.bigblog.com.au
http:
You will need to get the physical properties of the pipe to be used. This should be available from the pipe manufacturer.
Jeff
http:/
Jeff
A coal pile usually has a large caterpillar tractor on top pushing the material around. The expected loading from the tractor will be much different than what you would expect from just a material pile.
Don't forget to download the rest of the Technical Reports while you're there.
http:/
http://virtualpipeline.spaces.msn.com
