AL-6XN Welding
AL-6XN Welding
AL-6XN Welding
Does anyone have a welding procedure for welding AL-6XN to carbon steel?? I have searched our AWS D1.6 for any information and I have also gone to vendors with no luck as of now. I realzize it is not a desirable weld.
RE: AL-6XN Welding
For starters, I would suggest you review the information below regarding AL-6XN
http://www.alleghenyludlum.com/ludlum/pages/products/xq/asp/P.40/qx/product.html#
See page 38 of the AL-6XN source book. The filler metal for this weld joint should be a Ni-base, like Incoweld A or 82/182 depending on the welding process.
The key is to limit the heat input for the AL6-XN. I would suggest you qualify a weld procedure for this application.
RE: AL-6XN Welding
brane23;
I am going to ask one question regarding your OP, why are you welding CS to an alloy that has excellent corrosion resistance? Again, read the source book that I mentioned above to fully understand the uses of AL-6XN.
RE: AL-6XN Welding
The reason is that the inside of a vessel requires AL-6XN, however, the CS is an exterior item which corrosion is not a concern. I am aware of the uses of AL-6XN, however,not whether it is acceptable to weld CS to the exterior.
RE: AL-6XN Welding
If you are welding to the 'back side' in a corrosion application you will need to qualify the weld both mechanically and from a corrosion resistance standpoint.  Even just a bit of heat tint on the other side of the material will significantly lower the corrosion resistance, and you cannot remove it mechanically.
Rust never sleeps
Neither should your protection
http://www.trent-tube.com/contact/Tech_Assist.cfm
RE: AL-6XN Welding
AL-6XN can be readily welded to carbon steel using NiCrFe or NiCrMo-3, -4, -10 etc. filler metals. If AL-6XN is thin, advise welding with pulsed transfer, GMAW (low heat input)using Ar-He gas mixtures or applying an inert gas backing to the process side surface of the AL-6XN to mitigate the heat tinting described by Ed. Heat tint can also be removed by pickling.
