Grinding of a Stepped Shaft
I'm designing a 1/2" diameter steel shaft that has a 7/8" diameter portion at one end whose length may need to be ground to +-.0002. I'd like to spec in grinding on both ends of this 7/8" diameter section to get a satisfactory finish and parallelism. Is it possible to have this done? I guess it would require using the side of the grinding wheel to grind the inboard shoulder?
Thanks!
Thanks!
RE: Grinding of a Stepped Shaft
