Where can I look to find the composition of steel used for ASTM A 53?
3
Where can I look to find the composition of steel used to make ASTM A 53 and A 106 pipe?  I have some old(er) pipe that I need to evaluate its in-service condition that may or may not be ASTM spec pipe...  No records are available to me.  I want to make sure that the steel I am using to calibrate my UT machine is close in acoustic properties as I can get.
Thanks for the help.
RE: Where can I look to find the composition of steel used for ASTM A 53?
To get reliable information, you should obtain the documents from ASTM International:
http://www.astm.org
They cost $47 and $35, respectively.
If you can't/won't do this, then a random Google search provides some sites with some composition information.
Cory
Please see FAQ731-376: Eng-Tips.com Forum Policies for tips on how to make the best use of Eng-Tips Fora.
Thank you CoryPad.  I have both specifications in hard copy.  The table(s) provide only max% of a few elements.
I am looking to have step wedges made at a local machine shop and I have asked them to make them out of the same steel as A 53 and A 106.  Their reply was "OK, what grade of steel is that?"  I am at a loss to answer that question...
Since these step wedges for calibration purposes, you can specify a similar steel for UT. As you know, there are various Grades of A 53 and A 106. What I would do is to have the shop order
ASTM A 29 1025 carbon steel, hot wrought or finished.
That is how general the composition requirements are.  As long as you are not using an alloyed steel I don't see any major UT issues.  Things like grain size may end up being more important.
Rust never sleeps
Neither should your protection
http://www.trent-tube.com/contact/Tech_Assist.cfm
