ASTM G48 Method A 316 Accpetance Criteria
What is the acceptance criteria for 316L corrosion test?
Geoffrey D Stone FIMechE C.Eng;FIEAust CP Eng
www.waterhammer.bigblog.com.au
RE: ASTM G48 Method A 316 Accpetance Criteria
Cory
Please see FAQ731-376: Eng-Tips.com Forum Policies for tips on how to make the best use of Eng-Tips Fora.
Usually 316 is testing NaCl. The best bet might be an electrochemical test.
Rust never sleeps
Neither should your protection
http://www.trent-tube.com/contact/Tech_Assist.cfm
This test can be used for general evaluation of SS material (To find out whether the material is properly heat treated (Solution annealed).
If you are interested in corrosion rates in a given servece you may want to try Practice B, C, D.
Practice A is Microscopic exam. This is a rapid check method. This can also be used to eveluate the health of SS 316L.
But Practice "A" should not be used for rejection (Can be used only for acceptnce).
If one observes ditch structure one shuld then choose other appropriate test methods (Say A 262 Pr E) for further evaluation.
