broken broke view!
broken broke view!
I have this problem when I use the broken view function. After applying it to a part or parts, when I rebuild, the function seems to no longer be applied to the part in which was applied to. Sometimes I am using a second sheet and if I print then the not so broken views seem to extend past the printable area and cover up other details and views. HELP!!!
RE: broken broke view!
Are you only having problems when printing?
Can you update the printer driver?
Regg
Wes C.
No trees were killed in the sending of this message, but a large number of electrons were terribly inconvenienced.
