Car floor vibration
Car floor vibration
I have been getting wheel and floor vibration. So I have had my whhel balancing done. This seems to have cured the steering wheel vibration but the floor vibration is still present. The after affects can still be felt in my legs after i have got out. Please help
RE: Car floor vibration
Or you could have a defective CV joint if it's a front drive car.
Sounds to me like you need the services of a good mechanic; internet advice will only get you just so far...
Also I once had to use a wire hanger to hold up my exhaust pipe after the rubber one had broken. It worked but transmitted considerable vibration into the floor. Check you exhaust hangers.
C. Hugh (www.Hatch.ca)
